Date/Time: Sat, 18 May 2024 21:55:02 +0000
High/Low for Period Study
View Count: 875
[2015-08-10 13:59:34] |
Crtfyd - Posts: 277 |
Over the weekend I downloaded vs 1282 I changed nothing since then I opened charts this morning and 2 of 3 charts are not graphing the "High/Low for Period" study. My 1 min chart is fine, its charting. My 6 sec chart is missing the study all together. Not even in "Studies to Graph"(strange!) My 6 trades chart has it, but is not drawing it. Again, nothing was changed since download. As you can see from pic, It shows High 0.00 Low 0.00. (BTW For future versions, maybe being able to resize study windows. I tried to get them out of the way so you could see better, but wasn't able.) Thanks |
Private File |
[2015-08-10 17:21:38] |
The problem is the Based On setting is set to Cumulative Sum Of Study. This must be set to the "Main Price Graph".
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-10 17:22:34
[2015-08-10 17:37:56] |
I don't want it based on the Main graph. I want the High/Low of the Cumulative Sum Study (which is the Cumm Sum of the Ask/Bid Vol Diff study) |
[2015-08-10 18:35:48] |
We will add support for basing the High/Low for Time Period study on other studies, in the next release. This should be out by the end of the week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
