Date/Time: Sat, 18 May 2024 15:00:21 +0000
refernce
View Count: 808
[2015-08-09 05:35:57] |
User472677 - Posts: 316 |
Attached file contains the reference you asked for in the support ticket for BOTH indicators
Private File |
[2015-08-09 22:10:57] |
OK thank you for this. We will follow up with this as soon as we can but might not be for two weeks.
[2015-08-09 22:41:59] |
Also at this point, we are fairly certain the Moving Average-Adaptive Sierra Chart already has is the one you have provided in the file. It is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s93 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-09 22:42:18
[2015-08-10 14:36:40] |
Al SC Developer - Posts: 434 |
In the next version there will be a new study: Kaufman Adaptive Moving Average Binary Wave We have also verified that the Kaufman AMA that you reference is the same as our Moving Average - Adaptive. |
[2015-08-10 15:08:23] |
thx, appreciate your support.
