Date/Time: Wed, 15 May 2024 04:55:34 +0000
[User Discussion] - Price Display Format
View Count: 785
[2015-08-08 16:31:31] |
User21113 - Posts: 62 |
The following image shows the Current Price Line study where price is showing to the right of the last candle. The first image shows 115.52 The second image shows .52. Is it possible to show .52 instead of 115.52 ? This appears to be set in the study, Curent Price Line/Settings and Input/Value Format, where it is possible to change the price below the decimal point to .1, .01, .001. There is no option to change the price above the deminal point. Thanks |
Price Format.png / V - Attached On 2015-08-08 16:26:38 UTC - Size: 42.24 KB - 255 views |
[2015-08-09 22:50:33] |
This is not supported.
