Date/Time: Thu, 02 May 2024 20:19:20 +0000
ACSIL absolute value function
View Count: 3324
[2015-08-07 16:56:01] |
Johnny - Posts: 99 |
Hello, is there an ACSIL function that returns the absolute value of a variable?
[2015-08-07 17:19:20] |
Yes. There are the C++ functions for this. This is the one for taking the absolute value of a floating-point number: fabs() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-10 19:32:37] |
Thanks, can you create a special documentation for the most important and useful C++ functions in the section of ACSIL documentation for people that are not programmers like myself?
[2015-08-11 05:42:25] |
This is already documented here: http://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html#CppRef Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
