Date/Time: Thu, 16 May 2024 18:57:36 +0000
Vertical Grid lines
View Count: 1376
[2015-08-07 13:49:19] |
Crtfyd - Posts: 277 |
vs 1261 Seems the Vertical grid line doesn't show correct time. I have 6 trades per bar. As you can see the first (yellow) vertical grid line starts at 9:30:46 It does go 30 seconds from that point after, but I cant get it to be at the 9:30:30 mark. My charts start at 9:30:00 (EST) |
Private File |
[2015-08-08 01:48:27] |
We had looked at this earlier today but could not duplicate the problem. This is puzzling. Update Sierra Chart to the current version and see if you still notice this. But we would expect the result would be the same. The next thing we need to get from you is a Chartbook that contains a single chart demonstrating this problem. Here are the instructions to provide it: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-09 01:38:46] |
ejtrader - Posts: 688 |
Wondering if this is related to Chart settings -> split Data records field checked.
[2015-08-10 00:29:14] |
ejtrader: yes, split data records was checked, but after unchecking it, nothing changed, same results. Support: Downloaded latest version 1282 and it fixed it. |
[2015-08-10 01:16:45] |
Interesting this was resolved in the latest version. Anyway, this is good.
