Date/Time: Wed, 15 May 2024 13:07:19 +0000
New information box (I do not need it)
View Count: 812
[2015-08-07 08:54:53] |
User58159 - Posts: 62 |
Dear SC, after SC SW upgrade I have noted a new box with data, which I can see anytime I work with horizontal lines, .. (with my tools). I do not appreciate this new information box. Please, advice |
201508007_Dotaz.jpg / V - Attached On 2015-08-07 08:53:26 UTC - Size: 129.49 KB - 305 views |
[2015-08-07 09:40:20] |
Remove the check mark from Window >> Compact Tool Values Window.
[2015-08-07 15:30:08] |
Thank you a lot .. Nice weekend. |
