Date/Time: Thu, 16 May 2024 17:36:46 +0000
Sierra Chart Version 0 required? What?
View Count: 852
[2015-08-07 07:11:03] |
CustomIndicators - Posts: 126 |
Tonight, I compiled up a new shiny bot, and went to test it out. I have the current PreRelease version of Sierra Chart installed, and verified that by trying to install it again from Help > Download PreRelease (New Spreadsheets). I don't use spreadsheets, if that helps diagnose the issue. The bot compiled without any errors. Any idea what is wrong? I've attached a pic. Thanks |
version0orhigher.png / V - Attached On 2015-08-07 07:09:23 UTC - Size: 34.62 KB - 311 views |
[2015-08-07 08:12:58] |
What this indicates is that SCDLLName() is missing from the source code file.
[2015-08-07 08:22:40] |
*face-palm* Its always the little things that screw me up. Thank man. :) |
[2015-08-07 08:47:25] |
In the next release of Sierra Chart, the error text in parentheses after the DLL name in the Add Custom Study window will indicate what the problem is.
