Date/Time: Wed, 19 Aug 2026 23:25:42 +0000
Can't connect to LMAX for the first time
View Count: 1338
| [2015-08-07 03:15:49] |
| User31660 - Posts: 20 |
Hi Guys, Trying LMAX demo with FIX affixed to the account. I keep getting a waiting to connect message. This is what my message log says. Did I do something wrong? V/R D Software version: 1218 | 2015-08-06 22:02:59 Uses New Spreadsheets | 2015-08-06 22:02:59 Usage end date: 2015-08-18 | 2015-08-06 22:02:59 Enabled for: Advanced Features. | 2015-08-06 22:02:59 Enabled for: Sierra Chart Historical Data Service. | 2015-08-06 22:02:59 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-08-06 22:02:59 Active service: LMAX Trading | 2015-08-06 22:02:59 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-08-06 22:02:59 2015-08-06 22:02:59 Local computer clock time | 2015-08-06 22:02:59 2015-08-07 03:02:59 GMT time | 2015-08-06 22:02:59 2015-08-06 22:02:59 Time zone adjusted time | 2015-08-06 22:02:59 Time difference to server time: 2 seconds. | 2015-08-06 22:02:59 Program path: C:\SierraChart\ | 2015-08-06 22:02:59 Data Files path: C:\SierraChart\Data\ | 2015-08-06 22:02:59 OS Version Number: 6.2 | 2015-08-06 22:02:59 Locale Information: C | 2015-08-06 22:02:59 Checking for new symbol settings for lmax | 2015-08-06 22:02:59 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-08-06 22:02:59 HTTP connection to www.sierrachart.com:80 (1084) | Connected. | 2015-08-06 22:02:59 Symbol settings are up-to-date for lmax | 2015-08-06 22:03:00 LMAX Trading | Connecting. | 2015-08-06 22:13:28 LMAX Trading | Connecting to Demo Trade server: fix-ate.lmaxtrader.com:443 | 2015-08-06 22:13:28 LMAX FIX Trading socket (0) | Error on address resolution. Windows error code 11001: No such host is known. | 2015-08-06 22:13:28 LMAX FIX Trading socket (0) | Shutdown and closed. | 2015-08-06 22:13:28 LMAX FIX Trading: Socket connection was closed without any logout messages sent or received. | 2015-08-06 22:13:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-06 22:13:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-06 22:13:28 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-06 22:13:28 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-06 22:13:28 Date Time Of Last Edit: 2015-08-07 04:30:08
| [2015-08-07 04:29:32] |
The version of Sierra Chart you are running is out of date. Update with Help >> Download Current Version. Here are instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-08-07 11:30:49] |
Hello Sirs, Downloaded current version problem with no LMAX connecion is still there. Software version: 1281 | 2015-08-07 06:27:27 Uses New Spreadsheets | 2015-08-07 06:27:27 Usage end date: 2015-08-18 | 2015-08-07 06:27:27 Enabled for: Advanced Features. | 2015-08-07 06:27:27 Enabled for: Sierra Chart Historical Data Service. | 2015-08-07 06:27:27 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-08-07 06:27:27 Current selected Data/Trading service: LMAX Trading | 2015-08-07 06:27:27 Chart Update Interval: 500 | 2015-08-07 06:27:27 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-08-07 06:27:27 2015-08-07 06:27:27 Local computer clock time | 2015-08-07 06:27:27 2015-08-07 11:27:27 GMT time | 2015-08-07 06:27:27 2015-08-07 06:27:27 Time zone adjusted time | 2015-08-07 06:27:27 Time difference to server time: 3 seconds. | 2015-08-07 06:27:27 Program path: C:\SierraChart\ | 2015-08-07 06:27:27 Data Files path: C:\SierraChart\Data\ | 2015-08-07 06:27:27 OS Version Number: 6.2 | 2015-08-07 06:27:27 Locale Information: C | 2015-08-07 06:27:27 Checking for new symbol settings for lmax | 2015-08-07 06:27:27 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-08-07 06:27:27 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-08-07 06:27:27 Requesting symbol settings for lmax. Overwrite = on. | 2015-08-07 06:27:27 Symbol settings received. | 2015-08-07 06:27:28 Processed received symbol settings | 2015-08-07 06:27:28 LMAX Trading | Connecting. | 2015-08-07 06:27:32 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:27:32 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:27:32 LMAX FIX Trading socket (2) | Connected. | 2015-08-07 06:27:32 LMAX FIX Trading socket (2) | Starting SSL connection. | 2015-08-07 06:27:32 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-08-07 06:27:33 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-08-07 06:27:33 LMAX FIX Trading socket (2) | SSL connection established. | 2015-08-07 06:27:34 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:27:34 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:27:34 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:27:34 LMAX FIX Trading socket (2) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:27:34 LMAX FIX Trading socket (2) | SSL has been shut down. | 2015-08-07 06:27:34 LMAX FIX Trading socket (2) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:27:34 LMAX FIX Trading socket (2) | Shutdown and closed. | 2015-08-07 06:27:34 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:27:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:27:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:27:34 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:27:34 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:27:34 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:27:34 LMAX Trading | Connecting. | 2015-08-07 06:27:39 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:27:39 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:27:39 LMAX FIX Trading socket (3) | Connected. | 2015-08-07 06:27:39 LMAX FIX Trading socket (3) | Starting SSL connection. | 2015-08-07 06:27:39 LMAX FIX Trading socket (3) | SSL connection established. | 2015-08-07 06:27:39 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:27:39 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:27:40 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:27:40 LMAX FIX Trading socket (3) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:27:40 LMAX FIX Trading socket (3) | SSL has been shut down. | 2015-08-07 06:27:40 LMAX FIX Trading socket (3) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:27:40 LMAX FIX Trading socket (3) | Shutdown and closed. | 2015-08-07 06:27:40 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:27:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:27:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:27:40 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:27:40 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:27:40 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:27:40 LMAX Trading | Connecting. | 2015-08-07 06:27:45 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:27:45 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:27:45 LMAX FIX Trading socket (4) | Connected. | 2015-08-07 06:27:45 LMAX FIX Trading socket (4) | Starting SSL connection. | 2015-08-07 06:27:45 LMAX FIX Trading socket (4) | SSL connection established. | 2015-08-07 06:27:45 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:27:45 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:27:45 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:27:45 LMAX FIX Trading socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:27:45 LMAX FIX Trading socket (4) | SSL has been shut down. | 2015-08-07 06:27:45 LMAX FIX Trading socket (4) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:27:45 LMAX FIX Trading socket (4) | Shutdown and closed. | 2015-08-07 06:27:45 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:27:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:27:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:27:45 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:27:45 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:27:45 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:27:45 LMAX Trading | Connecting. | 2015-08-07 06:27:50 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:27:50 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:27:50 LMAX FIX Trading socket (5) | Connected. | 2015-08-07 06:27:50 LMAX FIX Trading socket (5) | Starting SSL connection. | 2015-08-07 06:27:50 LMAX FIX Trading socket (5) | SSL connection established. | 2015-08-07 06:27:51 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:27:51 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:27:51 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:27:51 LMAX FIX Trading socket (5) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:27:51 LMAX FIX Trading socket (5) | SSL has been shut down. | 2015-08-07 06:27:51 LMAX FIX Trading socket (5) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:27:51 LMAX FIX Trading socket (5) | Shutdown and closed. | 2015-08-07 06:27:51 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:27:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:27:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:27:51 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:27:51 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:27:51 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:27:51 LMAX Trading | Connecting. | 2015-08-07 06:27:56 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:27:56 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:27:56 LMAX FIX Trading socket (6) | Connected. | 2015-08-07 06:27:56 LMAX FIX Trading socket (6) | Starting SSL connection. | 2015-08-07 06:27:56 LMAX FIX Trading socket (6) | SSL connection established. | 2015-08-07 06:27:56 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:27:57 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:27:57 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:27:57 LMAX FIX Trading socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:27:57 LMAX FIX Trading socket (6) | SSL has been shut down. | 2015-08-07 06:27:57 LMAX FIX Trading socket (6) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:27:57 LMAX FIX Trading socket (6) | Shutdown and closed. | 2015-08-07 06:27:57 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:27:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:27:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:27:57 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:27:57 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:27:57 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:27:57 LMAX Trading | Connecting. | 2015-08-07 06:28:02 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:02 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:02 LMAX FIX Trading socket (7) | Connected. | 2015-08-07 06:28:02 LMAX FIX Trading socket (7) | Starting SSL connection. | 2015-08-07 06:28:02 LMAX FIX Trading socket (7) | SSL connection established. | 2015-08-07 06:28:02 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:02 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:02 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:02 LMAX FIX Trading socket (7) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:02 LMAX FIX Trading socket (7) | SSL has been shut down. | 2015-08-07 06:28:02 LMAX FIX Trading socket (7) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:02 LMAX FIX Trading socket (7) | Shutdown and closed. | 2015-08-07 06:28:02 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:02 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:02 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:02 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:02 LMAX Trading | Connecting. | 2015-08-07 06:28:07 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:07 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:07 LMAX FIX Trading socket (8) | Connected. | 2015-08-07 06:28:08 LMAX FIX Trading socket (8) | Starting SSL connection. | 2015-08-07 06:28:08 LMAX FIX Trading socket (8) | SSL connection established. | 2015-08-07 06:28:08 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:08 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:08 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:08 LMAX FIX Trading socket (8) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:08 LMAX FIX Trading socket (8) | SSL has been shut down. | 2015-08-07 06:28:08 LMAX FIX Trading socket (8) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:08 LMAX FIX Trading socket (8) | Shutdown and closed. | 2015-08-07 06:28:08 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:08 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:08 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:08 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:08 LMAX Trading | Connecting. | 2015-08-07 06:28:13 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:13 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:13 LMAX FIX Trading socket (9) | Connected. | 2015-08-07 06:28:13 LMAX FIX Trading socket (9) | Starting SSL connection. | 2015-08-07 06:28:13 LMAX FIX Trading socket (9) | SSL connection established. | 2015-08-07 06:28:14 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:14 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:14 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:14 LMAX FIX Trading socket (9) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:14 LMAX FIX Trading socket (9) | SSL has been shut down. | 2015-08-07 06:28:14 LMAX FIX Trading socket (9) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:14 LMAX FIX Trading socket (9) | Shutdown and closed. | 2015-08-07 06:28:14 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:14 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:14 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:14 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:14 Current selected Data/Trading service: LMAX Trading | 2015-08-07 06:28:18 LMAX Trading | Connecting. | 2015-08-07 06:28:19 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:19 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:19 LMAX FIX Trading socket (10) | Connected. | 2015-08-07 06:28:19 LMAX FIX Trading socket (10) | Starting SSL connection. | 2015-08-07 06:28:19 LMAX FIX Trading socket (10) | SSL connection established. | 2015-08-07 06:28:19 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:19 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:20 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:20 LMAX FIX Trading socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:20 LMAX FIX Trading socket (10) | SSL has been shut down. | 2015-08-07 06:28:20 LMAX FIX Trading socket (10) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:20 LMAX FIX Trading socket (10) | Shutdown and closed. | 2015-08-07 06:28:20 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:20 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:20 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:20 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:20 LMAX Trading | Connecting. | 2015-08-07 06:28:25 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:25 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:25 LMAX FIX Trading socket (11) | Connected. | 2015-08-07 06:28:25 LMAX FIX Trading socket (11) | Starting SSL connection. | 2015-08-07 06:28:25 LMAX FIX Trading socket (11) | SSL connection established. | 2015-08-07 06:28:25 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:25 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:25 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:25 LMAX FIX Trading socket (11) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:25 LMAX FIX Trading socket (11) | SSL has been shut down. | 2015-08-07 06:28:25 LMAX FIX Trading socket (11) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:25 LMAX FIX Trading socket (11) | Shutdown and closed. | 2015-08-07 06:28:25 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:25 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:25 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:25 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:25 LMAX Trading | Connecting. | 2015-08-07 06:28:30 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:30 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:30 LMAX FIX Trading socket (12) | Connected. | 2015-08-07 06:28:30 LMAX FIX Trading socket (12) | Starting SSL connection. | 2015-08-07 06:28:30 LMAX FIX Trading socket (12) | SSL connection established. | 2015-08-07 06:28:31 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:31 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:31 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:31 LMAX FIX Trading socket (12) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:31 LMAX FIX Trading socket (12) | SSL has been shut down. | 2015-08-07 06:28:31 LMAX FIX Trading socket (12) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:31 LMAX FIX Trading socket (12) | Shutdown and closed. | 2015-08-07 06:28:31 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:31 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:31 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:31 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:31 LMAX Trading | Connecting. | 2015-08-07 06:28:36 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:36 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:36 LMAX FIX Trading socket (13) | Connected. | 2015-08-07 06:28:36 LMAX FIX Trading socket (13) | Starting SSL connection. | 2015-08-07 06:28:36 LMAX FIX Trading socket (13) | SSL connection established. | 2015-08-07 06:28:36 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:37 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:37 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:37 LMAX FIX Trading socket (13) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:37 LMAX FIX Trading socket (13) | SSL has been shut down. | 2015-08-07 06:28:37 LMAX FIX Trading socket (13) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:37 LMAX FIX Trading socket (13) | Shutdown and closed. | 2015-08-07 06:28:37 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:37 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:37 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:37 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:37 LMAX Trading | Connecting. | 2015-08-07 06:28:42 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:42 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:42 LMAX FIX Trading socket (14) | Connected. | 2015-08-07 06:28:42 LMAX FIX Trading socket (14) | Starting SSL connection. | 2015-08-07 06:28:42 LMAX FIX Trading socket (14) | SSL connection established. | 2015-08-07 06:28:42 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:42 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:42 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:42 LMAX FIX Trading socket (14) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:42 LMAX FIX Trading socket (14) | SSL has been shut down. | 2015-08-07 06:28:42 LMAX FIX Trading socket (14) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:42 LMAX FIX Trading socket (14) | Shutdown and closed. | 2015-08-07 06:28:42 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:42 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:42 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:42 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:42 LMAX Trading | Connecting. | 2015-08-07 06:28:47 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:47 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:47 LMAX FIX Trading socket (15) | Connected. | 2015-08-07 06:28:48 LMAX FIX Trading socket (15) | Starting SSL connection. | 2015-08-07 06:28:48 LMAX FIX Trading socket (15) | SSL connection established. | 2015-08-07 06:28:48 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:48 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:48 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:48 LMAX FIX Trading socket (15) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:48 LMAX FIX Trading socket (15) | SSL has been shut down. | 2015-08-07 06:28:48 LMAX FIX Trading socket (15) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:48 LMAX FIX Trading socket (15) | Shutdown and closed. | 2015-08-07 06:28:48 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:48 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:48 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:48 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:48 LMAX Trading | Connecting. | 2015-08-07 06:28:53 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:53 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:53 LMAX FIX Trading socket (16) | Connected. | 2015-08-07 06:28:53 LMAX FIX Trading socket (16) | Starting SSL connection. | 2015-08-07 06:28:53 LMAX FIX Trading socket (16) | SSL connection established. | 2015-08-07 06:28:53 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:54 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:28:54 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:28:54 LMAX FIX Trading socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:28:54 LMAX FIX Trading socket (16) | SSL has been shut down. | 2015-08-07 06:28:54 LMAX FIX Trading socket (16) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:28:54 LMAX FIX Trading socket (16) | Shutdown and closed. | 2015-08-07 06:28:54 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:28:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:28:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:28:54 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:28:54 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:28:54 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:28:54 LMAX Trading | Connecting. | 2015-08-07 06:28:59 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:28:59 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:28:59 LMAX FIX Trading socket (17) | Connected. | 2015-08-07 06:28:59 LMAX FIX Trading socket (17) | Starting SSL connection. | 2015-08-07 06:28:59 LMAX FIX Trading socket (17) | SSL connection established. | 2015-08-07 06:28:59 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:28:59 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:00 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:00 LMAX FIX Trading socket (17) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:00 LMAX FIX Trading socket (17) | SSL has been shut down. | 2015-08-07 06:29:00 LMAX FIX Trading socket (17) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:00 LMAX FIX Trading socket (17) | Shutdown and closed. | 2015-08-07 06:29:00 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:00 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:00 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:00 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:00 LMAX Trading | Connecting. | 2015-08-07 06:29:05 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:05 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:05 LMAX FIX Trading socket (18) | Connected. | 2015-08-07 06:29:05 LMAX FIX Trading socket (18) | Starting SSL connection. | 2015-08-07 06:29:05 LMAX FIX Trading socket (18) | SSL connection established. | 2015-08-07 06:29:05 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:05 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:05 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:05 LMAX FIX Trading socket (18) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:05 LMAX FIX Trading socket (18) | SSL has been shut down. | 2015-08-07 06:29:05 LMAX FIX Trading socket (18) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:05 LMAX FIX Trading socket (18) | Shutdown and closed. | 2015-08-07 06:29:05 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:05 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:05 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:05 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:05 LMAX Trading | Connecting. | 2015-08-07 06:29:10 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:10 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:10 LMAX FIX Trading socket (19) | Connected. | 2015-08-07 06:29:10 LMAX FIX Trading socket (19) | Starting SSL connection. | 2015-08-07 06:29:10 LMAX FIX Trading socket (19) | SSL connection established. | 2015-08-07 06:29:11 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:11 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:11 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:11 LMAX FIX Trading socket (19) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:11 LMAX FIX Trading socket (19) | SSL has been shut down. | 2015-08-07 06:29:11 LMAX FIX Trading socket (19) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:11 LMAX FIX Trading socket (19) | Shutdown and closed. | 2015-08-07 06:29:11 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:11 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:11 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:11 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:11 LMAX Trading | Connecting. | 2015-08-07 06:29:16 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:16 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:16 LMAX FIX Trading socket (20) | Connected. | 2015-08-07 06:29:16 LMAX FIX Trading socket (20) | Starting SSL connection. | 2015-08-07 06:29:16 LMAX FIX Trading socket (20) | SSL connection established. | 2015-08-07 06:29:16 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:17 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:17 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:17 LMAX FIX Trading socket (20) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:17 LMAX FIX Trading socket (20) | SSL has been shut down. | 2015-08-07 06:29:17 LMAX FIX Trading socket (20) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:17 LMAX FIX Trading socket (20) | Shutdown and closed. | 2015-08-07 06:29:17 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:17 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:17 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:17 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:17 LMAX Trading | Connecting. | 2015-08-07 06:29:22 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:22 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:22 LMAX FIX Trading socket (21) | Connected. | 2015-08-07 06:29:22 LMAX FIX Trading socket (21) | Starting SSL connection. | 2015-08-07 06:29:22 LMAX FIX Trading socket (21) | SSL connection established. | 2015-08-07 06:29:22 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:22 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:22 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:22 LMAX FIX Trading socket (21) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:22 LMAX FIX Trading socket (21) | SSL has been shut down. | 2015-08-07 06:29:22 LMAX FIX Trading socket (21) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:22 LMAX FIX Trading socket (21) | Shutdown and closed. | 2015-08-07 06:29:22 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:22 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:22 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:22 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:22 LMAX Trading | Connecting. | 2015-08-07 06:29:27 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:27 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:27 LMAX FIX Trading socket (22) | Connected. | 2015-08-07 06:29:28 LMAX FIX Trading socket (22) | Starting SSL connection. | 2015-08-07 06:29:28 LMAX FIX Trading socket (22) | SSL connection established. | 2015-08-07 06:29:28 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:28 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:28 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:28 LMAX FIX Trading socket (22) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:28 LMAX FIX Trading socket (22) | SSL has been shut down. | 2015-08-07 06:29:28 LMAX FIX Trading socket (22) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:28 LMAX FIX Trading socket (22) | Shutdown and closed. | 2015-08-07 06:29:28 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:28 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:28 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:28 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:28 LMAX Trading | Connecting. | 2015-08-07 06:29:33 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:33 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:33 LMAX FIX Trading socket (23) | Connected. | 2015-08-07 06:29:33 LMAX FIX Trading socket (23) | Starting SSL connection. | 2015-08-07 06:29:33 LMAX FIX Trading socket (23) | SSL connection established. | 2015-08-07 06:29:33 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:34 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:34 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:34 LMAX FIX Trading socket (23) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:34 LMAX FIX Trading socket (23) | SSL has been shut down. | 2015-08-07 06:29:34 LMAX FIX Trading socket (23) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:34 LMAX FIX Trading socket (23) | Shutdown and closed. | 2015-08-07 06:29:34 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:34 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:34 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:34 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:34 LMAX Trading | Connecting. | 2015-08-07 06:29:39 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:39 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:39 LMAX FIX Trading socket (24) | Connected. | 2015-08-07 06:29:39 LMAX FIX Trading socket (24) | Starting SSL connection. | 2015-08-07 06:29:39 LMAX FIX Trading socket (24) | SSL connection established. | 2015-08-07 06:29:39 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:39 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:39 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:39 LMAX FIX Trading socket (24) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:39 LMAX FIX Trading socket (24) | SSL has been shut down. | 2015-08-07 06:29:39 LMAX FIX Trading socket (24) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:39 LMAX FIX Trading socket (24) | Shutdown and closed. | 2015-08-07 06:29:39 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:39 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:39 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:39 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:39 LMAX Trading | Connecting. | 2015-08-07 06:29:44 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:45 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:45 LMAX FIX Trading socket (25) | Connected. | 2015-08-07 06:29:45 LMAX FIX Trading socket (25) | Starting SSL connection. | 2015-08-07 06:29:45 LMAX FIX Trading socket (25) | SSL connection established. | 2015-08-07 06:29:45 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:45 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:45 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:45 LMAX FIX Trading socket (25) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:45 LMAX FIX Trading socket (25) | SSL has been shut down. | 2015-08-07 06:29:45 LMAX FIX Trading socket (25) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:45 LMAX FIX Trading socket (25) | Shutdown and closed. | 2015-08-07 06:29:45 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:45 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:45 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:45 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:45 LMAX Trading | Connecting. | 2015-08-07 06:29:50 LMAX Trading | Connecting to Demo Trade server: fix-order.london-demo.lmax.com:443 | 2015-08-07 06:29:50 LMAX FIX Trading socket (0) | Resolved address fix-order.london-demo.lmax.com to IP 91.215.166.65 | 2015-08-07 06:29:50 LMAX FIX Trading socket (26) | Connected. | 2015-08-07 06:29:50 LMAX FIX Trading socket (26) | Starting SSL connection. | 2015-08-07 06:29:50 LMAX FIX Trading socket (26) | SSL connection established. | 2015-08-07 06:29:51 LMAX FIX Trading: Sending the Logon message. | 2015-08-07 06:29:51 LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-08-07 06:29:51 LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-08-07 06:29:51 LMAX FIX Trading socket (26) | SSL shutdown indicates not able to send 'close notify'. | 2015-08-07 06:29:51 LMAX FIX Trading socket (26) | SSL has been shut down. | 2015-08-07 06:29:51 LMAX FIX Trading socket (26) | SSL object has been freed. SSL state is now disconnected. | 2015-08-07 06:29:51 LMAX FIX Trading socket (26) | Shutdown and closed. | 2015-08-07 06:29:51 LMAX FIX Trading: Logged out and disconnected. | 2015-08-07 06:29:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-08-07 06:29:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-08-07 06:29:51 LMAX FIX Trading: DisconnectFIX called. | 2015-08-07 06:29:51 LMAX Trading | Disconnected from trade and market data servers. | 2015-08-07 06:29:51 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-08-07 06:29:51 |
| [2015-08-07 11:33:19] |
Disregard!!!!! I saw the bad creditials message and changed my password stuff up, now works. Thank you! |
