Date/Time: Mon, 06 May 2024 03:03:18 +0000
TPO tick size
View Count: 1843
[2015-08-06 17:17:28] |
User57210 - Posts: 121 |
I trade US Equities, and have to switch between hundreds of symbols a day. I rely on TPO charts heavily. It's a lot of work to constantly have to go in and adjust the TPO "Letter/Block Increment in Ticks" to make the proper looking profiles for given stock. (Smaller tick settings are needed for lower priced stocks, while higher tick settings for higher priced stocks.) A few solutions come to mind. 1) A hotkey to where we could easily adjust the tick size for the TPO chart. 2) An available setting to adjust tick size to a desired ratio compared with ATR. Thanks as always. |
[2015-08-06 17:50:39] |
The only thing we can say is that you can set the Tick Size to a custom value for a stock symbol through the Global Symbol Settings. Here is the documentation: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php You will have to add stock symbols individually there. So when you change the symbol of a chart, this custom Tick Size will be applied and the TPO Profiles will be based on it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-06 17:52:27
[2018-03-12 23:31:42] |
User401511 - Posts: 33 |
What tick sizes do you use for equities @user57210?? For example I use 1.00 for $amzn and .25 for $tsla seems to work for me. Is that what you do... just find something that works for you?
[2018-03-12 23:35:43] |
think I answered my own question... use ATR on a minute chart or 3 min chart etc.
[2020-09-14 18:20:52] |
BlueVein - Posts: 34 |
Has Sierra considered adding something to automate this process? Jut got equities data and it is quite frustrating to have to adjust each.
