Date/Time: Thu, 02 May 2024 04:23:31 +0000
Change size of MDI Window Tabs
View Count: 1646
[2013-06-11 23:46:55] |
Jochen Penther - Posts: 7 |
How to Change the size and/or font of MDI Window Tabs. The idea of these Tabs is nice. But they are to small for efficient work. All other things i found a configuration for. But only configuration of this Tabs and of chartbook Tabs i have not found. Please help me to configure These Tabs. Thanks. |
[2013-06-12 10:39:53] |
tobi - Posts: 351 |
I personally don't find them to small. They work just fine. Jochen, are you aware, that you can change the text of the MDI Window Tabs? If not, right-click on a MDI Window Tab and choose "Rename". Regarding the Chartbook Tabs, maybe you want to use a shorter chartbook file-name!? |
[2014-11-21 09:58:52] |
phaedonk - Posts: 350 |
Is it possible to have two rows of MDI tabs instead of only one? I have many charts in my chartbook and have to constantly scroll the list of tabs with my mouse to find the chart I want.
[2019-03-14 12:44:03] |
chart_warrior - Posts: 96 |
Old post but is it actually possible? Looking to have 2 rows of tabs instead of having to scroll left and right |
[2019-03-14 20:19:01] |
We will see about this with the new tab bar we are developing which will be out soon.
[2020-05-29 11:56:34] |
Any news on the new tabs?
[2020-05-29 12:00:38] |
Yes this is all supported. Update to the current version you will see the settings in Global Settings >> General Settings. And you can also control the font size: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
