Date/Time: Wed, 15 May 2024 16:27:43 +0000
keyboard mapping for X & Y Constant Relationship Scaling and the Scale range types
View Count: 796
[2015-08-06 02:39:26] |
User742717 Mike - Posts: 86 |
Hello, I switch on and off the chart scale "X & Y Constant Relationship Scaling" regularly. I also change scale range type regularly. Ie when the charts moves, I switch X/Y off, I go back to automatic, then I lock X/Y again and repeat. I find this the best way to zoom in/out of charts. Edit: Just to add more info, when changing symbol on the quote board the lock X/Y charts don't look correct, then I have to reset them manually, as explained above. It would save me a lot of clicking if I could bind keys to it. Cheers Mike. PS: Thanks for the support on this forum, SC is beast, but without the support forum, it would be only half the beast! Date Time Of Last Edit: 2015-08-09 10:38:26
[2015-08-07 05:04:06] |
We will see about this, but it is not likely anything we could do soon.
