Date/Time: Sun, 05 May 2024 20:07:39 +0000
Which SC supported brokers offer options trading?
View Count: 1747
[2015-08-05 09:38:30] |
User760942 - Posts: 120 |
I’d like to use Seirra Chart to do trade Options. Which brokers connected to Seirra Chart offer Options trading?
[2015-08-05 09:58:39] |
Futures options or stock options?
[2015-08-05 10:42:09] |
Any type of options you have available.
[2015-08-05 16:52:03] |
For futures and stock options you can use Interactive Brokers: https://www.sierrachart.com/index.php?page=doc/IB.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-05 17:20:38] |
Are they the only choice? I'm fine using seperate brokers for stock options and futures options, if thats what will give me more choices. |
[2015-08-05 17:50:26] |
For stock options really the only practical choice would be Interactive Brokers. For futures options, CTS does support options trading but Sierra Chart does not support options currently through the CTS system. And we are not sure of other trading services or trading platforms that support options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-05 17:50:59
[2015-08-05 18:48:21] |
Cool. Is this the complete list of brokers and trading platforms you are currently connected to? https://www.sierrachart.com/index.php?page=doc/data.php I'll review each one to see if any aside from Interactive Brokers and CTS systems offer options trading (since you said "And we are not sure of other trading services or trading platforms that support options.") |
[2015-08-05 19:06:29] |
Yes.
[2015-08-06 21:44:18] |
Cool. Thanks for the info.
[2015-08-12 06:07:33] |
Can I use Sierra Chart to trade forex options with Interactive Brokers? I could not find any info in this link on which Interactive Brokers Symbols I’d use to do this http://www.sierrachart.com/index.php?page=doc/IBSymbols.html |
[2015-08-12 06:51:25] |
Yes you can. Can you tell us the symbol, the security type, and the exchange for one of the particular options contracts you want to trade so we can explain the format for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-12 08:48:10] |
I’d like to buy a call options contract for 10,000 units of EUR/USD. Exchange= International Securities Exchange (ise.com) Symbol= EUI |
[2015-08-14 03:23:29] |
We apologize for the delay with this. It takes a little time to research this. We have just not had a free moment yet. We will get to it by the end of the day.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-14 03:23:46
[2015-08-14 05:22:07] |
Actually what would help us is that if you could find the particular product you want to trade here: https://www.interactivebrokers.com/en/index.php?f=1563&ns=T And give us a link to it then we can tell you the specific symbol to use in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-14 10:39:21] |
Is this what you mean by product link? Its the closest I could find in the link you supplied. https://www.interactivebrokers.com/en/index.php?f=products&p=opt&ns=T Either way, you'll see this link says currency options are available on the ISE Options Exchange (ISE). I'd like to trade these currency options. |
[2015-08-14 10:51:30] |
Here it is: http://www1.interactivebrokers.ch/contract_info/v3.9/index.php?action=Details&site=GEN&conid=167815680 This Option Format is what you need to use: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Option Use Format 1. So you just need to take each of the elements of the option contract, to form the complete symbol. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-15 05:37:58
[2015-08-15 04:02:11] |
That works, thanks!
