Date/Time: Thu, 09 May 2024 20:44:06 +0000
second monitor
View Count: 782
[2015-08-05 06:25:36] |
User38993 - Posts: 61 |
Is it possible to put A chartbook on first monitor and B chartbook on second monitor?
[2015-08-05 07:52:38] |
This is not currently supported unless you run two copies of Sierra Chart.
[2015-08-05 08:12:14] |
I actually tried running two copies, but one lose connection while the other one get the connection.
[2015-08-05 08:13:47] |
Yes, this can be true depending upon the particular trading system you are connecting to. We know that Rithmic allows multiple connections. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
