Date/Time: Mon, 14 Sep 2026 09:02:33 +0000
SIERRA/IOAMT CHARTS
View Count: 2148
| [2013-06-11 21:52:19] |
You need to download and install Sierra Chart from here: http://www.sierrachart.com/index.php?l=doc/download.php After the installation login with the very same Account Name and Password that you use to log into this Support Board and website with. The IOAMT chartbooks will be automatically downloaded for you. Do you know what Data feed or trading service you will be using Sierra Chart with? They are all listed here: https://www.sierrachart.com/index.php?l=doc/data.php Please let us know if you need further help or have additional questions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-11 21:52:38
