Date/Time: Fri, 10 May 2024 06:03:21 +0000
SC backup
View Count: 765
[2015-08-04 22:28:34] |
davidbrooke - Posts: 55 |
What are the available means for Sierra Charts backup? I saw where you could put Sierra Charts on USB memory stick. Meaning just copying C:\Sierra\Chart would be the backup. Please advise. Date Time Of Last Edit: 2015-08-04 22:29:10
[2015-08-04 22:58:14] |
Backing up Sierra Chart is as simple as backing up the folder that Sierra Chart is installed to. This is all.
[2015-08-05 04:04:06] |
I noticed that C:\SierraChart\Data is the largest directory by size. Can any of the files in this directory be omitted?
[2015-08-05 04:20:52] |
Yes. You can delete the Intraday data files you are not using. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#DeletingChartDataFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-05 20:54:28] |
I read the url that was referred but I believe my situation is a bit different. I have used two datafeed providers. Which I see filenames related to both datafeeds. For example: Rithmic: ESU5-CME.scid IQFeed: @ESU15.scid I'm currently using the rithmic datafeed and will not need the IQfeed symbols. What would be the best way to rid the IQfeed symbol files located in C:\SierraChart\Data? Thanks |
[2015-08-05 21:16:12] |
You can just simply delete those files. This is all.
