Date/Time: Mon, 13 May 2024 20:25:50 +0000
Scroll wheel activated Chart Calculator
View Count: 1065
[2015-08-04 08:13:35] |
User93464 - Posts: 52 |
Is it possible to assign the Chart calculator function to the depression of the scroll wheel?
[2015-08-04 08:56:43] |
We would not know. Certainly there is no way within Sierra Chart to do this.
[2015-08-05 01:21:58] |
Hieronymus - Posts: 51 |
Yes I have it set as that with my mouse. You have to have a programmable mouse, I have a cheap Logitech mx310 and I just use the Logitech software to assign the hotkey of the calculator tool to it.
[2015-08-05 05:41:38] |
Thanks Hieronymus, I'll give that a try
