Date/Time: Thu, 09 May 2024 23:04:55 +0000
DOM One Click
View Count: 1696
[2015-08-04 08:07:21] |
User240686 - Posts: 86 |
Is there a way to move stops and target by just clicking a price as opposed to clicking and dragging the current stop or target. This would make it complete |
[2015-08-04 08:08:08] |
No. You have to move order line.
[2015-08-04 08:16:28] |
can you change that
[2015-08-04 09:12:36] |
i am wondering why you do not add this feature to make things faster for your clients...Ninjatrader does it as do many others
[2015-08-04 18:19:03] |
There is this Global Settings >> Chart Trade Setting which may do what you want: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartTradeSettings#UseClickReleaseClickAdjust Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-04 18:44:29] |
its nearly there but it would be really good if you only had to click the price for the stop or target to move as opposed to clicking current price and then move it to desired target or stop
[2015-08-04 19:14:12] |
This does not make sense. How is a program to even know what order you want to move. There are no plans to add this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-04 23:52:53] |
davidbrooke - Posts: 55 |
I'm not aware of a one click trade adjustment in NT7. Currently it is a two step process...click on the order to move then click the new price level to move to.
[2015-08-04 23:58:31] |
If this is how it works, then Sierra Chart supports this. As you move your Pointer to the new location to left click again, you will see the order move with the Pointer movement when using this option: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#ChartTradeSettings#UseClickReleaseClickAdjust Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-05 10:10:00] |
No. you just click the price and the order moves
[2015-08-05 10:11:29] |
Its smart in that if price is above your entry and you are clicking below price then it moves the stop. If you click above the entry then it moves the target. Infinity also have this as do NT |
[2015-08-06 00:01:22] |
i960 - Posts: 360 |
While I can see how they coded the logic I haven't the slightest how this would even work with multiple orders on the same instrument.
