Date/Time: Mon, 06 May 2024 12:06:12 +0000
[User Discussion] - Alert/Indicator to highlight BID/ASK change of Number Bar
View Count: 879
[2015-07-31 15:05:14] |
NumbersBars - Posts: 141 |
Hi, I am trying to create an alert or indicator to indicate when there is sequential increase/decrease of volume at BID/ASK column of number bar. Please refer to the attached image I have browsed through the forum but can't find related topic. Could SC support or any user with programming skill shed some light? or advice? Thanks. Date Time Of Last Edit: 2015-07-31 22:35:53
Private File |
[2015-07-31 19:01:58] |
For this you will need to use ACSIL: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html You will need to use the Volume at Price data: https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#AccessingVolumePriceDataPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
