Date/Time: Sun, 05 May 2024 07:34:33 +0000
custom study choices
View Count: 747
[2015-07-31 14:27:22] |
davidbrooke - Posts: 55 |
I was reviewing the documentation concerning a custom study. It seems there are two ways to create a custom study: 1. Programming 2. Spreadsheet Since I'm not a programmer I found this info for spreadsheet: https://www.sierrachart.com/index.php?page=doc/doc_StudiesSystemsAlerts.php Please let me know if the above info is correct for me to create some simple custom studies. If not, please re-direct me. Thanks |
[2015-07-31 18:29:44] |
Yes, the Spreadsheet Study can be used to create custom studies but it is not as efficient as ACSIL: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
