Date/Time: Mon, 29 Apr 2024 17:06:11 +0000
symbol dropdownlist in control bar?
View Count: 1146
[2015-07-31 08:07:07] |
4646ed - Posts: 230 |
Y'all wrote a while back :"It is in our longer-term development plans to add a Symbol drop-down list box to a ToolBar which can be added to any detached window." Any way this will be added to the new control bar in the near future? |
[2015-07-31 09:23:00] |
Yes. This has already been developed and is now available. You can add this through Global Settings >> Customize Toolbars>> ToolBar #. It contains the symbols specified through Chart >> Associated Watch List. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-31 12:38:34] |
i see. so you didnt add a dropdown list, just a button to open assoc watch list. i was hoping for a simple editable dropdown menu of instruments that doesnt take up as much space as the assoc watch list. or am i not using it right? Date Time Of Last Edit: 2015-07-31 12:44:07
[2015-07-31 13:07:22] |
tobi - Posts: 351 |
In Customize ToolBar# have a look at Special Items (all the way at the bottom) and add "Watch list". That should do what you're looking for.
[2015-07-31 13:09:29] |
Aah. Excellent. thankyou
