Date/Time: Tue, 30 Apr 2024 04:26:15 +0000
How to change the 2nd symbol units?
View Count: 1172
[2015-07-31 01:17:08] |
davidbrooke - Posts: 55 |
I have just setup a chart with 2 symbols and the added symbol's units are in decimal but need to be in fraction. How can I change the units? I have attached a photo. The bottom symbol is shown in decimal. Thanks |
2symbol1.png / V - Attached On 2015-07-31 01:16:41 UTC - Size: 27.32 KB - 243 views |
[2015-07-31 01:32:32] |
I managed to find out how to change the units but I still have a problem with this specific symbol. US 10 year notes trade in 1/2 of 1/32 meaning 126 28.5/32 is a valid unit while US 30 year bonds trade in 1/32. When either is added to the other chart...the added symbol's units are fraction but are 1/4 of 1/32. How can I get the exact units for each symbol? I have attached a photo. Thanks |
2symbol2.png / V - Attached On 2015-07-31 01:32:27 UTC - Size: 31.29 KB - 276 views |
[2015-07-31 01:47:21] |
In regards to post #2, there is not a solution to this when overlaying another symbol. If you actually want to see the bar values for the overlaid chart use the Tool Values Window: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
