Date/Time: Sat, 27 Apr 2024 19:22:41 +0000
Session time for cumulative delta bars
View Count: 805
[2015-07-31 00:10:40] |
davidbrooke - Posts: 55 |
I'm trying to setup session times so that the cumulative delta bars start at 0 for each session. Right now the best I can do is set the session start and end times for 9:30 & 16:15 and I have only one session. I have read: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php and I have set the global symbol settings for session and evening start and end times as well as the chart session and evening start and end times. Ideally this is the sessions I would like to have: 9:30-16:15 and 16:30-9:29:59 Basically two sessions consuming 24 hours that would each start at a 0 value. If I enter: session start and end times 9:30-16:15 evening start and end times 16:30-9:29:59 I only get a reset to the 0 level at 16:30. Thanks |
[2015-07-31 18:52:04] |
What you want is not supported. The reset is only once per day. You need to use two separate charts each with their own Session Times. One for the day session and one for the evening session.
