Date/Time: Tue, 07 May 2024 19:48:20 +0000
More than 1 symbol per chart
View Count: 749
[2015-07-30 19:11:03] |
davidbrooke - Posts: 55 |
I'm trying to add more than 1 symbol to a chart. Please see attached photo with blue arrows signifying the symbols. I found this info: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#OverlayingMultipleSymbols Is this the correct way? If not please advise. Thanks |
2symbol.PNG / V - Attached On 2015-07-30 19:10:45 UTC - Size: 26.26 KB - 298 views |
[2015-07-30 19:21:57] |
Yes, that is the correct method.
[2015-07-30 19:25:55] |
Thanks for your reply!
[2015-07-31 05:15:20] |
Once the 2nd symbol is added to a chart, can the "symbol that was added" chart be deleted or does that chart need to remain?
[2015-07-31 05:45:40] |
I removed the added symbols chart and that stopped the updating on the chart with 2 symbols. I guess I answered my own question, that the original chart needs to stay.
[2015-07-31 06:59:25] |
The chart must remain.
