Date/Time: Sat, 18 May 2024 23:31:02 +0000
Bid Ask volume and GOMCD
View Count: 1773
[2015-07-30 19:01:58] |
davidbrooke - Posts: 55 |
I'm trying to find out whether there is an indicator in Sierra Charts like GOMCD? GOMCD take the bid/ask volume and cumulates the data. I have attached a photo that has a blue arrow indicating the GOMCD indicator on the chart. I have found the following Sierra Charts indicators that come close: Bid volume Ask volume Ask/Bid volume difference bars The Ask/Bid volume difference bars would work if it didn't start from 0 each time. Please advise. Thanks |
gomcdtest.PNG / V - Attached On 2015-07-30 18:58:59 UTC - Size: 23.51 KB - 491 views |
[2015-07-30 19:05:48] |
Yes this is available. It is called Cumulative Delta Bars: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s292 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
