Date/Time: Mon, 06 May 2024 16:32:17 +0000
OJU5 Frozen OJ futures
View Count: 921
[2015-07-30 18:16:43] |
User438810 - Posts: 50 |
There's a misprint of a selloff from 123.50-1.2205. Also I can't get more than a few bars of data on the 30min chart. I've deleted and dloaded all data, updated to the newest version, and set contracts to volume based rollover back adjusted. Any suggestions?
[2015-07-30 18:16:58] |
I'm using OEC data.
[2015-07-30 19:13:58] |
Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps We made some changes just now. After this re-download the data in the chart with Edit >> Delete All Data and Download. Let us know if you still see a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
