Date/Time: Fri, 10 May 2024 15:15:58 +0000
VWAP study and chart types
View Count: 989
[2015-07-30 18:13:54] |
Johnny - Posts: 99 |
Hello, the VWAP study can only be used with time based charts. Would it possible to add a calculation option based on bar count, the same way that the VbP study has, so that this study works for other chart types as well? Thanks |
[2015-07-30 18:46:30] |
Anything is possible, but we are not taking new development requests now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-30 18:46:40
[2015-08-02 21:31:32] |
Ok, can you register this feature for future implementation? Also, when will you be accepting new feature requests again?
[2015-08-02 22:07:16] |
It is nearly impossible for us to say when we are accepting new feature requests. We would only consider the feature if there is a lot of interest in it or if the user wants to pay for some of the development. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-05 17:23:41] |
I believe that the suggestion that I have made is not minor but rather fundamental. From my point of view, not only the VWAP study but all the available studies should work for all chart types, except for cases that the calculation formula of the indicator does not allow that. Just imagine if the Volume Profile study could only be used with time based charts but not with renko, range or tick charts. How restrictive would that be?
[2015-08-05 17:44:45] |
The Volume Weighted Average Price does already work for all chart types.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-05 17:45:15
