Date/Time: Fri, 03 May 2024 14:41:45 +0000
extending rectangle tool
View Count: 1130
[2015-07-30 18:02:25] |
Dennis B. - Posts: 263 |
When I use the ext.rect. I get a funny little dialog box. How to disable ? Just upped to 1278
[2015-07-30 18:07:19] |
Maybe you are referring to the Compact Tool Values Window. Here is the documentation for it: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData You can disable it through the Window menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-30 18:31:54] |
Great, that fixed that little annoyance. Running 3 SC's on 3 monitors and those new floating toolbars sure like to move around on Ver. 1278..LOL...
[2015-07-30 18:46:06] |
those new floating toolbars sure like to move around on Ver. 1278 Do you mean they are not remembering their position when Sierra Chart is restarted?
[2015-07-30 19:21:31] |
I just upped to 1278 today so give me a little time to play. Actually I shut down SC and my puter after close every day. When I do that I close out the toolbars automatically. Just a habit
[2015-07-30 19:33:49] |
OK, because we do see the Control Bars when detached, do remember their position even when hidden.
