Date/Time: Sun, 28 Apr 2024 06:58:55 +0000
Can you graphically mark the high volume price level in a bar on a range bar chart?
View Count: 2128
[2015-07-30 03:32:19] |
Shane - Posts: 31 |
The numbers bar study has an option to highlight the price level within the bar that has most volume traded (what I would call the bar's high volume node). Is there a way to graphically mark a bar's high volume node on a 'regular' chart? For example, on a range bar chart, placing a left or right hash on the price level that has the highest volume? regards, shane |
[2015-07-30 04:23:45] |
ganz - Posts: 1048 |
Shane https://www.sierrachart.com/supportboard/showthread.php?t=37616 |
[2015-07-30 05:10:58] |
Shane - Posts: 31 |
Thank you Ganz. Are you saying that what I'm asking for is not natively supported and must be handled in ACSIL? That's fine. I can write the ACSIL. I just don't want to do it if it's already supported. I appreciate your effort and sharing of the studies, but I cannot use a custom study if I don't have the source code. kind regards, shane |
[2015-07-30 05:21:25] |
Shane just follow the link - the source code is available :) |
[2015-07-30 06:57:12] |
We thought this could not be done with any of the standard studies but it can be with the Volume by Price study. Here is an image of the chart: http://www.sierrachart.com/image.php?l=1438239367869.png Refer to the attachment for the settings. Only the Point of Control Subgraph is set to be visible and uses a Dash Draw Style. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-30 06:58:23
2015-07-30_185544.png / V - Attached On 2015-07-30 06:56:46 UTC - Size: 20.8 KB - 561 views |
