Date/Time: Tue, 07 May 2024 18:42:37 +0000
What configuration file are the Global Settings/General Settings/Alerts kept in?
View Count: 1037
[2015-07-29 19:04:28] |
ArnulfoPenaloza - Posts: 7 |
When I give my chartbook to my teammate, I would also like to give them the config file where the Global Alert-Sound assignment settings are kept. For example, Alert 1 - is marked DOW on mine using DOW.wav My teammate may be set as Alert 1 - is marked as RLM using RLM.wav I wish to give him my Alert config file so he does not have to manually reset his Global Alert assignments. Thank You, Arnie |
[2015-07-29 19:19:48] |
This is the Sierra3.CFG file located in the Sierra Chart installation folder. It contains no passwords or other private information.
