Date/Time: Sun, 28 Apr 2024 14:18:15 +0000
"sierra trend" under user contributes studies
View Count: 993
[2015-07-29 18:57:05] |
Sierra Chart - Max - Posts: 5597 |
When you add this study to a candlestick chart the candles are blue and red, is there any way to change the colors? When you go to the basic graphic settings section, the changes do not take. Sierra Chart Support |
[2015-07-30 05:02:17] |
You may be able to change the colors through the Subgraphs tab of the Study Settings window for that study. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
