Date/Time: Fri, 04 Jul 2025 00:15:23 +0000
Rename Control Bar
View Count: 1180
[2015-07-29 13:20:14] |
User228426 - Posts: 14 |
Is it possible to rename "Control Bar 1," if yes how? ie: change the dialog box name "Control Bar 1" to "Status Bar" |
[2015-07-29 17:06:28] |
Not at this time.
[2024-07-29 10:25:42] |
Chris32 - Posts: 61 |
While it is great to be able to have 12 different control bars for each instance of Sierra Chart, I must say my memory often fails me there ; it would be very useful if we could give them descriptive names. As we are able to do with study collections for example.
