Date/Time: Wed, 01 May 2024 14:43:03 +0000
Different results on different computers
View Count: 831
[2015-07-29 07:12:52] |
User44052 - Posts: 34 |
Hello. I have a setup producing different results on different computers. What could be the possible causes? I mean where should I start looking? Exactly the same chartbook, using exactly the same DLL, but the results don't match. I appreciate your assistance. |
[2015-07-29 07:50:46] |
Is this an automated trading system? The other thing we need to know is what Trading or Data are you using Sierra Chart with? The most likely reason has to do with differences in the underlying data in the chart. You should examine the price and volume data (if it depends upon this) bar by bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-29 07:51:24
[2015-07-29 09:08:09] |
Not yet, I'm hoping to automate it eventually. The data feed is the same source: TransAct futures. I've checked the bars as you have mentioned, and the two bars (where the discrepancy was noted yesterday) are different in their volume and even their start time (about 2 seconds difference). How do I rectify this? |
[2015-07-29 17:41:39] |
Make sure your computer's clock is set accurately. Refer to help topic 38: Http://www.sierrachart.com/index.php?page=doc/helpdetails38.html Re-download the data in the chart with Edit >> Delete All Data and Download. Refer to help topic 43: Differences With Data and Chart Bars Between Services / Connections / Chart Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
