Date/Time: Wed, 01 May 2024 17:51:53 +0000
Time Line Doesnt Appear w/ stocks which have a price over 100
View Count: 730
[2015-07-29 01:05:09] |
MKL17 - Posts: 35 |
I am using the time line function and have tested with various stocks, all those under 100 seem to work fine, those above 100 do not.
[2015-07-29 02:06:39] |
We do not observe this problem. Did you change the Scale Settings for the Time Line study? It should be at the default of the User-Defined Scale Range. Here are the instructions to check this: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
