Date/Time: Fri, 26 Apr 2024 04:49:04 +0000
Volume Bars on the Currency futures
View Count: 1411
[2015-07-28 10:40:25] |
User867101 - Posts: 2 |
Hello, All of the volume indicators completely fill the region and all of the bars are the same height on all of the currency futures charts. I have tried every volume indicator, every scale setting and all do the same thing. The gold and oil and USDX all work properly. The problem is all currency futures with all of the volume indicators. How do I get the volume indicators to scale properly so the volume bars are different length based on the actual volume? Thanks for the help.
[2015-07-28 10:55:21] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-28 12:40:08] |
http://www.sierrachart.com/image.php?l=1438086498671.png Here is a screen shot of the chart with the volume bars as the only study loaded as per the instructions. |
[2015-07-28 18:39:26] |
This is not a chart of a currency future. It is an FX index. It is completely different. The volume will generally be consistent bar to bar for those. Volume data on those is not really relevant. Here is some more information about them: Market Statistics, US Dollar Index, other/new FX indices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
