Date/Time: Sat, 12 Jul 2025 00:58:01 +0000
Alerts from various study's
View Count: 1012
[2015-07-23 17:46:33]
Moti - Posts: 63
Hello
I would like to get Alerts base on various study's :
1) High low close of bar
2) Number bars calculated value Study SG
3) Volume Value Area % SG
Where I need to write the formula ?
[2015-07-23 19:23:03]
Refer to this page:
https://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html
[2015-07-23 22:11:17]
Moti - Posts: 63
Please advise where to write the formula?
Thank You.
[2015-07-24 06:22:28]
The formula should be put on the Alerts tab of the Chart >> Chart Settings window and it can refer to any study on the chart.
We see your Sierra Chart account is expired. Are you using a different account than what you are using on this Support Board?
[2015-07-24 08:13:50]
Moti - Posts: 63
Thank you.
I use Sierra via TransaAct.
But. I consider to use again Sierra charts directly.
Thank You.
[2015-07-27 13:09:30]
Moti - Posts: 63
s for : "The formula should be put on the Alerts tab of the Chart >> Chart Settings window and it can refer to any study on the chart".
I would like to display different alerts/colors for different "patterns" (about 9 for short & and 9 for long ).
Please guide me.
Thank you,
Moti
[2015-07-27 18:17:32]
Use the Color Bar Based on Alert Condition study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245
[2015-07-28 11:35:58]
Moti - Posts: 63
Does Color Bar Based on Alert Condition study can get data from:
1) Number bars calculated value Study SG
2) Volume Value Area % SG
[2015-07-28 17:38:13]
1. Yes.
2. Yes, but we are not totally sure what you are referring to because of reference to the %.
