Date/Time: Mon, 29 Apr 2024 19:38:10 +0000
[User Discussion] - Offering To The Community: Lines 5
View Count: 1965
[2015-07-19 14:14:57] |
bjohnson777 (Brett Johnson) - Posts: 284 |
I've been programming some indicators from my base tool kit and am offering them to the community. I request they be added into the main SC distro once checked over. From the "Display Study Documentation" button: Lines 5. Draws 5 horizontal lines across a subgraph. This is mainly useful when multiple indicators will be on one subgraph. This will create a fixed scale and a place holder for the subgraph. This also allows for graphs stacked on top of each other to be seen easier if those graphs have lines which could then be turned off to avoid overlapping. Be sure to change the graph scale of any indicators added on top. ----- Minor update 2016-10-15. No major function changes. Regular compiles moved to "Brett Johnson's Standard Tool Kit" DLL. Offering To The Community: Brett Johnson's Standard Tool Kit Date Time Of Last Edit: 2016-10-15 06:52:23
Lines5.cpp - Attached On 2016-10-15 06:52:08 UTC - Size: 5.27 KB - 421 views Lines5.dll - Attached On 2016-10-15 06:52:13 UTC - Size: 72 KB - 413 views |
[2015-07-20 12:06:10] |
Minor update to hide the lines in the Tools Values Window. ----- Edit: Download latest version from the first post. Date Time Of Last Edit: 2016-02-07 02:50:28
[2016-10-15 06:52:34] |
Today's DLL was compiled with the M$VC++ change over. You may need to update your SC version. Keep your previous DLL version until you've tested the new compile. Most changes were made to shut up useless M$VC++ warnings when compiling. There are a few compile warnings left about "argument" that can be ignored. No real functionality changes have been made. |
