Date/Time: Fri, 20 May 2022 16:38:00 +0000
CTS Fix
View Count: 1507
[2013-06-10 07:19:44] |
TastyRisk - Posts: 119 |
I saw that you have this in beta already. Do you have any idea when it will be finished ? |
[2013-06-10 15:21:24] |
ganz - Posts: 1048 |
TastyRisk hi FYI http://www.ctsfutures.com/wiki/T4%20API%20FIX.MainPage.ashx gd lck |
[2013-06-10 15:50:12] |
Ahhh, I see the message. Thanks, Ganz.
[2013-06-10 16:35:08] |
joshtrader - Posts: 377 |
Does this mean that the implementation in SC will not be final until CTS themselves make the API on their side final?
[2013-06-10 16:49:48] |
We are working with CTS, to complete development of FIX integration to T4.
