Date/Time: Mon, 14 Jul 2025 20:36:44 +0000
[User Discussion] - cumulative delta bars display
View Count: 3446
[2013-06-10 04:31:55] |
remynz - Posts: 17 |
Hi there, is it possible to display this study as per the attached screenshot? If so how do i go about this and also how do i change the colours for the +ve delta and -ve delta? Thanks Date Time Of Last Edit: 2013-06-10 04:32:15
[2013-06-10 16:01:03] |
TastyRisk - Posts: 119 |
Try this: 1. Use the "cumulative delta bars - volume" study and set it to be hidden. 2. Add a "moving average simple" based on the above study with period set to 1. Set the second study's subgraph as per the attached picture. (things to change are; a. Draw style. and b. Auto-Color.) img: http://www.sierrachart.com/Download.php?Folder=SupportBoard&download=586 |
[2013-06-10 16:44:30] |
Sierra Chart has a Cumulative Delta Bars study. Please see: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s292 For instructions to work with studies, refer to: https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingStudiestoaChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-10 22:30:40] |
Try this: 1. Use the "cumulative delta bars - volume" study and set it to be hidden. 2. Add a "moving average simple" based on the above study with period set to 1. Set the second study's subgraph as per the attached picture. (things to change are; a. Draw style. and b. Auto-Color.) img: http://www.sierrachart.com/Download.php?Folder=SupportBoard&download=586 Thats exactly what i wanted - green grapes to you.. thanks vm! |
[2013-06-10 22:39:28] |
You're welcome Mq
