Date/Time: Sun, 28 Apr 2024 23:48:01 +0000
problem with chart trading window
View Count: 689
[2015-07-16 22:43:58] |
User90940 - Posts: 35 |
Hi I followed instructions and saved my trade window configurations as FIMS whith PT 8 ticks and SL 8 ticks.But if I try to open possition I have SL 8 ticks and PT 12 ticks.Where is the problem?
bandicam 2015-07-16 23-38-34-315.jpg / V - Attached On 2015-07-16 22:43:52 UTC - Size: 1.18 MB - 322 views |
[2015-07-16 23:59:29] |
Each chart has its own Trade Window and you probably do not have the correct Trade Window open. Go to the particular chart you are trading from and select Trade >>Open Trade Window for Chart and adjust the Attached Order settings there. For more information, refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#SettingsNotApplying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-17 00:00:05
