Date/Time: Thu, 02 May 2024 04:29:10 +0000
SCStudyInterfaceRef
View Count: 1136
[2015-07-16 19:14:41] |
mkata - Posts: 103 |
When setting the function name are these two lines equivalent? SCStudyInterfaceRef sc SCStudyGraphRef sc Are they to be used for different circumstances? |
[2015-07-16 19:25:57] |
Yes they are equivalent. SCStudyGraphRef is old and should not be used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-16 19:58:11] |
Ok. I should probably let you know that it is also being used in the SC provided template.cpp
[2015-07-16 20:03:06] |
OK we will fix that.
