Date/Time: Fri, 26 Apr 2024 16:29:53 +0000
CTS T4 Topstep trader with Sierra
View Count: 1956
[2013-06-10 02:37:06] |
Benjie - Posts: 1 |
Hello, I have a problem that after I connected with Sierra successfully to my CTS/T4 top step trader account, I cannot load any symbol... When I click File >> Find Symbol. The list is empty is this because I have a trial sierra charts ?? or is it a problem from top step traders side ? |
[2013-06-10 03:12:00] |
For some reason you did not receive the symbol list. Go to Global Settings >> Symbol Settings. Press the Update From Server button. Wait for the symbols to be received and the Symbols list to fill in and then press OK.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-10 03:12:12
