Date/Time: Wed, 01 May 2024 12:13:41 +0000
alphabetical order.in SC historical
View Count: 791
[2015-07-16 16:15:50] |
Ed Meckelborg - Posts: 71 |
Can the entries in the list of charts be in alphabetical order. This is in the SC historical
[2015-07-16 20:13:33] |
What specific list of charts are you referring to?
[2015-07-16 21:25:44] |
As I click on HC to open up a chart for a specific stock they are not listed in alphabetical order. It's a jumbled mess. Can this list be put in alphabetical order. Thanks |
[2015-07-16 21:28:37] |
Yes of course you can do this. Update Sierra Chart to the current release by selecting Help >> Download Current Version. In the open file window click on the "File Name" header to sort it alphabetically. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
