Date/Time: Sun, 28 Apr 2024 09:22:38 +0000
scale
View Count: 764
[2015-07-16 15:31:49] |
Crtfyd - Posts: 277 |
vs 1261 For some reason my scaling on my charts are screwed up. I never changed anything except added the Square 9 study. When I scroll out or go to beginning of day (1 day loaded, the chart looks like the attached pic. I have to resize everytime by going into "Interactive scale range" to get back to normal charts. Also I noticed on the scale settings it has 6.55 on the range (which is NOT selected), but when I deleted it, the charts seemed to be ok, then I went back and noticed it was there again. Is it suppose to be there? where did it come from, I don't see the relevance. Thanks |
Private File Private File |
[2015-07-16 18:00:16] |
Reset the scales by selecting Chart >> Reset Scales. The image you provided does not meet our requirements. It must only contain the one study in question. Refer to: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image When you remove the study from the chart, is the scale correct? If so, then the problem is with the study values or a possible problem with the underlying price data causing incorrect study values. Disregard the Range value on the Scale Settings window. It is not relevant with an Automatic Scale Range. We will not answer any further questions about it in this case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-16 18:01:44
