Date/Time: Wed, 15 May 2024 04:41:41 +0000
[User Discussion] - Visual C++ etal
View Count: 1670
[2015-07-15 21:17:38] |
djcurcio - Posts: 236 |
I am new to using C++ for Sierra. New to Microsoft Visual C++. So when I go to http://www.sierrachart.com/index.php?page=doc/doc_VCExpress.php#DownloadAndInstall click on Navigate to this page for Visual C++ Express I get https://www.visualstudio.com/downloads/download-visual-studio-vs Which is Visual Studio 2013 90-day free trials help please thanks |
[2015-07-15 23:07:36] |
What you need Microsoft is currently calling: "Express 2013 with Update 4 for Windows Desktop". This should be free. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-16 06:30:21] |
Hmm - got this far and went off the rails here. Trying to reclaim my inner geek from years of non-use. LOL Help please Thanks https://www.sierrachart.com/index.php?page=doc/doc_VCExpress.php#CreateProject Save your work. You now have all the elements of a custom study but it still won't compile. Next we will configure and build our study dll Configuring Project Properties Can't find referenced items here |
[2015-07-17 09:06:43] |
Really need Sierra documentation help using the 2013 C++ version at this point. Willing to invest my weekend working on getting my code compiled and into a Sierra dll But the Sierra documentation at this point does not correlate with the Msft screens Help please. thanks |
[2015-07-20 22:47:02] |
User911705 - Posts: 89 |
I've tried searching for the item mentioned in post #2, but the links I get to at MS show as no longer available. It looks like they have a new package called VS Community. Is that what we want to use? I hate to start down a rabbit hole with a piece of software that isn't the correct thing to be using.
[2015-07-21 00:05:05] |
Visual Studio community seems to be OK: https://www.visualstudio.com/en-us/products/visual-studio-community-vs.aspx Microsoft is always changing things with new names, major changes in user interfaces (although usually not much with their development tools), and changes to their website. This causes all of the documentation which has been written about their products to made significantly less effective. I am certain this is one thing they have no regard for and Microsoft should be terribly ashamed by this. One thing about Sierra Chart is that it is very stable and changes are incremental and minimal. Just generally gradual new improvements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-21 00:05:42
[2015-07-21 02:36:08] |
I'm stuck on getting the code to compile into a dll with the std header stuff. The documentation disconnect to 2013 has me stymied. your help is sincerely appreciated I'm trying to reclaim my inner geek. LOL dj |
[2015-07-21 02:37:06] |
using community 2013
[2015-07-30 15:49:42] |
SteveW - Posts: 16 |
djcurcio -- I downloaded the 2010 version from this site. installing it as we speak. http://microsoft-visual-cpp-express.soft32.com/. Update: I'm running Windows 7 and the MSoft .NET framework libraries are not compatible with this older app and so the app doesn't build. I'm trying the 2013 version next.
Date Time Of Last Edit: 2015-07-30 16:48:59
[2015-08-08 17:48:32] |
The 2013 version works for me.
