Date/Time: Wed, 25 May 2022 03:16:22 +0000
Fibonacci logarithmic measurement tool
View Count: 1087
[2013-06-09 18:49:47] |
Alexey A Sidorovitch - Posts: 9 |
Is it possible to have a Fibonacci retracement tool which can be set to logarithmic measurements instead of current standard arithmetic scale measuring in nominal units? There was a post about this some time ago. Maybe you have some solution by now?
Date Time Of Last Edit: 2013-06-09 18:54:39
[2013-06-10 21:53:08] |
We had a brief look at this, and it is not something we are able to offer. The calculations with the Price Retracement tool are done based upon the level percentages and the actual values of the endpoints of the drawing. There is no consideration of scaling.
