Date/Time: Fri, 30 Oct 2026 12:08:40 +0000
Connection window (green/red) and values toolbar are absent
View Count: 1258
| [2015-07-15 13:26:19] |
| User411334 - Posts: 38 |
Hello! I have a bit of a trouble. Here is what my toolbar looks like now. Windows that show connection status and values in the main toolbar are no longer visible and i don't know how to turn them on. Is there a way i can enable them? I am using SC 1269 and windows 8.1. Thank you!
| [2015-07-15 16:55:30] |
Refer to this post here about this: New Control Bar to replace ToolBar and Status Bar | Post: 63440 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
