Date/Time: Mon, 29 Apr 2024 09:23:58 +0000
chart screenshot
View Count: 3546
[2015-07-15 12:44:46] |
User742717 Mike - Posts: 86 |
Hi, I've searched the forum and help for a screen capture feature of charts.. but couldn't find any. Does it exists? Most charting apps have a way to capture a single chart or screen into a jpeg file. Thanks |
[2015-07-15 15:22:49] |
ertrader - Posts: 645 |
The first 4 options in the edit menu cover ways to capture chart images
[2015-07-15 17:55:22] |
Refer to this page for instructions: https://www.sierrachart.com/index.php?page=doc/doc_Image_to_Server.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-17 08:59:26] |
It should ask if the user wants to upload (and in options disable it).. I mostly want it stored with the same file name and I run a batch to move it. Rarely do I want to share screenshots. I use upload charts with overlay and upload desktop. I notice the image management doesn't have a 'delete all' or a auto delete after 10-30 days etc option. I'm guessing you guys auto delete these after some time right? But thanks, I can get what I need done :) Date Time Of Last Edit: 2015-07-17 09:01:41
[2015-07-17 09:56:31] |
You have to manually delete the images. There is no automatic deleting of images. There is the ability to delete multiple images at once by selecting them with a checkmark and doing the delete at once in the Image Management control panel. What you are interested in is Edit >>Screen Images >> Save Chart to File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-17 10:00:20] |
Yes, but there's no save Desktop to file And I don't want to complicate my script with unique names of images. I'll be sure to delete all my images every month. Thanks again. |
