Date/Time: Tue, 07 May 2024 22:08:28 +0000
Switch between Topstep practice and combine accounts?
View Count: 899
[2015-07-13 20:33:45] |
bryden mg firth - Posts: 4 |
Hi there, So I have 2 accounts with Topstep trader, and within T4 I can change between my practice, and my combine account, but I can't see this is an option in Sierra Charts, it alway logs into my Practice account. This means I can't trade my combine through Sierra charts and have to have T4 open as well. If I can't switch from with in Sierra, is there any way to force sierra to connect to my combine account instead? Thanks. |
[2015-07-13 21:01:35] |
You should see both accounts listed the list of Trade Accounts on the Trade Windows. Refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#SelectingTradeAccount Do you see both accounts listed? You really should. There is the CTS username and then under that username all of your trading accounts exist. So Sierra Chart is logging into CTS using the username and then discovering all of the available accounts upon the connection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-13 21:02:02
