Date/Time: Sat, 04 May 2024 00:32:15 +0000
[User Discussion] - Ordr Type / Spreadsheet for Trading
View Count: 688
[2015-07-13 15:42:40] |
djcurcio - Posts: 236 |
1. In the trading spreadsheet, when a buy or sell order is issued, what is the default order type? 2. What is the code to generate a BUY ASK and a SELL BID? 3. What is the code to BUY at the close of the previous bar and SELL at the close of the previous bar. Thanks |
[2015-07-13 17:23:37] |
The first two questions are answered here: https://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php#BuyEntryLimit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-13 22:39:01] |
Sawtooth - Posts: 3993 |
3) For close of bar signals in row 3 of columns K-Z...BR: If Signal Only On Bar Close is set to No, reference row 4. If Signal Only On Bar Close is set to Yes, reference row 3. |
