Date/Time: Sat, 27 Apr 2024 17:13:28 +0000
Show every pip in trading DOM and showing the current spread
View Count: 1063
[2015-07-13 01:49:08] |
Hieronymus - Posts: 51 |
Is there a way to show every decimal place, like 1.12341,1.12342,1.12343 etc. Also is there a way to have the current spread (w/ FXCM spot FX) on the chart or DOM? It's kind of hard to devise what it is just by looking at the DOM. |
[2015-07-13 05:05:59] |
I've solved the pip/decimal issue. Still looking for spread indicator.
[2015-07-13 18:25:27] |
Here is the documentation which explains this: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#DisplayDOMSpread Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-13 18:25:43
